After being involved in an accident, the pedestrian broke his arm. There is a wound on his forearm (about 5 cm), from which dark- colored blood is flowing continuously. What should be done to stop the bleeding?
Ticket 10 · question 7 Updated:
  1. Flush the wound with water.
  2. Raise the wounded person's arm and apply a tight dressing. ✓ Correct answer
  3. Lubricate the wound with an alcoholic solution of iodine.
Correct answer Raise the wounded person's arm and apply a tight dressing.
