Ticket 3 · question 40 Updated:
  1. The audible signal device does not work. ✓ Correct answer
  2. The cooling system does not provide a stable thermal mode of operation of the engine.
  3. In both cases.
Correct answer The audible signal device does not work.
If the audible signal device (horn) does not work.
A non-functioning horn is on the list of defects prohibiting operation of a vehicle. At first sight the horn looks like a minor component, but it is the driver's only means of warning someone who cannot see him: a pedestrian stepping into the carriageway without looking, the driver of the car alongside changing lanes in the blind spot, or a child emerging from between parked cars.
Its importance grows on mountain roads and tight bends — of which Armenia's roads have plenty — where two drivers cannot see each other until the last moment and sound arrives before sight. Remember that the lawful use of the horn is to prevent a collision, not to express displeasure; but a vehicle that lacks this capability is deprived of a preventive tool, and for that reason has no right to be on the road.
The question's trap is the cooling system. Failure to maintain a stable thermal regime for the engine is a performance fault that damages the engine itself, but it is not on the closed list of prohibiting defects. Apply this chapter's general rule: everything relating to brakes, steering, vision, lighting, signalling and mandatory safety equipment is on the list; faults affecting the engine's performance and durability are not.
• A cooling system not working properly damages the engine but is not on the list of prohibiting defects; the option is tempting only because it describes a genuine fault. • Since the second item is not on the list, the "in both cases" option is wrong too.
