Ticket 3 · question 36 Updated:
  1. The tightness of the hydraulic brake actuator is broken.
  2. The turn signal lamps with white lights are installed at the rear.
Correct answer In both cases.
Both the loss of sealing in the hydraulic brake actuator and the fitting of white indicator lamps at the rear.
Both items are on the list of prohibiting defects; one from the brakes category and one from the lamp colours category.
A hydraulic brake works on a simple principle: fluid is incompressible, so the pressure of your foot reaches all four wheels undiminished. The moment the circuit's sealing fails and air or a leak enters the system, that chain breaks; the pedal softens, its travel lengthens, and at worst it goes to the floor without the car slowing. The main danger of this defect is that it is hidden: in gentle urban braking you may feel only slight softness, but in the first emergency stop all braking capacity is lost. That is why no degree of leakage can be overlooked.
A white indicator lamp at the rear is also an offence, because indicator colour must be yellow/amber on both sides of the vehicle. White light at the rear has another defined meaning: reversing. On seeing white light the driver behind thinks the car in front is coming towards him, when it merely intends to turn; or, conversely, he fails to grasp the intention to turn and pulls into its path.
The rule: every colour on a vehicle's lamps carries a unique message; swapping colours means sending a false message.
• Correct but incomplete; the loss of sealing in the hydraulic brake circuit really does prohibit operation, but this option ignores the white rear indicator item. • A white indicator at the rear is independently an offence too, but choosing it alone means you have dropped the brake defect from the answer.
