Which sign gives the driver an advantage over oncoming vehicles?
Ticket 4 · question 11 Updated:
  2. 2
  3. 3
  4. 4 ✓ Correct answer
  5. 5
Correct answer Option 4 — 4
Sign number 4, that is "priority over oncoming vehicles".
Sign number 4 is a blue rectangle with one large white arrow pointing up and one small red arrow pointing down. The blue colour means good news for you: on the narrow section ahead you go first and the oncoming vehicle must wait. Sign number 2 is the mirror image of this one; round with a red border and a large red arrow, meaning you must give way.
The point to memorise is that in both signs the large arrow belongs to whoever has priority, and the red arrow always represents the oncoming traffic. If the red arrow is small, you are in the right; if the red arrow is large, you must stop. The shape helps too: a circle with a red border is a duty and a prohibition, a blue rectangle is information and a privilege.
This pair of signs is posted at narrow bridges, defiles and sections where the road width is not enough for two vehicles to pass at once. If the legislator did not assign priority for such a place, two drivers would enter from either end of the narrow stretch and either lock together in the middle or reverse out; both outcomes are dangerous on a mountain road. Assigning priority one-sidedly takes the decision out of a moment-by-moment negotiation between two drivers.
• Sign 1 is merely a "two-way traffic" warning and gives priority to nobody; it simply announces that oncoming traffic exists. • Sign 2 is exactly the reverse of the correct answer: with it you are obliged to give way to the oncoming vehicle. • The yellow diamond means priority road and gives priority only over minor roads at junctions, not over the traffic coming towards you. • Sign 5 shows the direction of travel in the lanes and allocates one lane to route vehicles; its subject is lane allocation, not priority against oncoming traffic.
