If the cargo protrudes 0.3 m sideways beyond the outer edge of the vehicle's marker light, must it be marked with the "Large Cargo" identification sign during daylight hours, and at night or in conditions of insufficient visibility also with a white lamp or reflector at the front and a red lamp or reflector at the rear?
Correct answer No
- At what maximum speed are passenger cars allowed to drive on the road sections within the area of influence of this road sign?
- Should the cargo be marked "Large Cargo" during daylight hours in case of protruding from the side of the vehicle 0.5 m from the external border light under "Cargo with large border light" recognition sign, and during night hour and under the condition of insufficient visibility, also white from the front, and rear with red lamp or reflectors?
- Should the cargo be marked "Large Cargo" during daylight hours in case of protruding from the side of the vehicle 1.2 m from the external border light under "Cargo with large border light" recognition sign, and during night hour and under the condition of insufficient visibility, also white from the front, and rear with red lamp or reflectors?
- Should the cargo be marked "Large Cargo" during daylight hours in case of protruding from the side of the vehicle 0.3 m from the external border light under "Cargo with large border light" recognition sign, and during night hour and under the condition of insufficient visibility, also white from the front, and rear with red lamp or reflectors?
- This sign indicates the approach of such a tunnel
