In case of loss of consciousness, breathing or blood circulation, in what position will you lay the victim to give him/her first aid?
Ticket 10 · question 42 Updated:
  1. On his/her back by putting a pillow under his/her head
  2. On his/her back with his/her her legs stretched
  3. Give the victim a stable side position so that the bent knees touch the ground and the upper hand is under the cheek. ✓ Correct answer
Correct answer Give the victim a stable side position so that the bent knees touch the ground and the upper hand is under the cheek.
