In this case of straight driving is it allowed to
Ticket 1 · question 66 Updated:
  1. Bypass the truck on the right.
  2. Continue driving only after the truck has passed
  3. Both of these cases are permissible ✓ Correct answer
Correct answer Both of these cases are permissible
Both are permitted: you may pass the truck using the right-hand lane, or you may wait. You are inside a built-up area and your direction has more than one lane — a double solid line separates the oncoming side and a full traffic lane continues on your right — while the truck ahead has stopped with hazard lights and indicator to turn left. In a built-up area on a road with two or more lanes per direction the driver may choose the most suitable lane, so moving right and passing the truck is an ordinary lane change, not illegal overtaking. The difference from the similar rural question is not the truck but whether what lies to your right is a lane or a shoulder.
