How is first aid for fractures of the limbs provided, if there are no braces and the means at hand to prepare make it?
Ticket 10 · question 49 Updated:
  1. The upper limb extends along the waist and is attached to the waist. The lower limbs are connected to each other by placing a soft cloth between them.
  2. The upper limb, bent at the elbow joint, resting on a scarf, is attached to the waist. The lower limbs are connected to each other by placing a soft cloth between them. ✓ Correct answer
  3. The upper extremity, bent at the elbow joint, resting on a scarf, is attached to the waist. The lower limbs are connected with each other
Correct answer The upper limb, bent at the elbow joint, resting on a scarf, is attached to the waist. The lower limbs are connected to each other by placing a soft cloth between them.
