What is the first aid for superficial heat burns (redness, swelling of the skin, blisters filled with transparent fluid at the burned surface, severe pain)?
Ticket 10 · question 50 Updated:
  1. Pour cold water on the burned surface, cover with a sterile napkin and bandage tightly.
  2. Open the blisters, clean the burned surface from the remnants of clothes, cover with a sterile napkin (do not bandage), if possible put a cold matter and give the victim a drink
  3. Freeze the burned surface with water for 20 minutes. Without opening the blisters, remove the remnants of clothing, cover the burned surface with a sterile cloth (do not bandage), if possible, put a cold matter and give the victim a drink. ✓ Correct answer
Correct answer Freeze the burned surface with water for 20 minutes. Without opening the blisters, remove the remnants of clothing, cover the burned surface with a sterile cloth (do not bandage), if possible, put a cold matter and give the victim a drink.
