What kind of first aid should be provided in case of a craniocerebral injury with a wound on the hairy part of the head?
Ticket 10 · question 39 Updated:
  1. Stop the bleeding by applying direct pressure to the wound, apply a compression bandage to the wound. In case of loss of consciousness, provide a stable side position for the victim. If possible, apply anything cold to head injury. ✓ Correct answer
  2. Immobilize the cervical spine using a homemade collar. Put a sterile cotton swab on the wound, lay the victim on his/her back with the legs up. If possible, put something cold on the head.
  3. It is forbidden to put a neck brace. It is necessary to cover the wound with medical adhesive tape, lay the victim on his/her side.
Correct answer Stop the bleeding by applying direct pressure to the wound, apply a compression bandage to the wound. In case of loss of consciousness, provide a stable side position for the victim. If possible, apply anything cold to head injury.
