What does this marking mean?
Ticket 7 · question 27 Updated:
  1. Crosswalk.
  2. The place where a bicycle lane crosses a roadway. ✓ Correct answer
  3. The place where cattle cross.
Correct answer The place where a bicycle lane crosses a roadway.
The place where a cycle path crosses the carriageway.
In the picture the carriageway is cut across by two parallel rows of small squares, and the red car is approaching that place from above. This pattern shows the place where a cycle path crosses the carriageway.
The key to identification is the shape of the bands. A pedestrian crossing is drawn with wide, continuous bands along the direction of the car's travel and from a distance looks like a striped panel; but a cycle crossing has only two dotted edges with the middle empty — exactly what you see in the picture.
Why does this difference matter? Because the safety distance you need is not the same. A cyclist reaches the carriageway faster than a pedestrian and is seen later, and a cycle path usually runs parallel to the pavement and is hidden behind trees and parked cars. On seeing this marking, reduce speed and, before reaching it, look both ways along the cycle path; in the picture, right after this place there is the entrance to an adjacent area, which shortens the view still further.
The exam trap is the option "pedestrian crossing", the most familiar meaning of any transverse marking.
• A pedestrian crossing is marked with wide, continuous bands along the direction of the car's travel, not with two rows of small squares at the two edges of an empty band. • A cattle crossing is announced by a warning sign and has no such special marking on the carriageway.
