With which road sign can a yellow dashed line marking be applied?
Ticket 7 · question 21 Updated:
  1. Stopping is forbidden"
  2. No Parking. ✓ Correct answer
  3. Parking is prohibited on odd days of the month.
Correct answer No Parking.
Together with the "parking prohibited" sign.
There are two yellow markings beside the kerb or the edge of the carriageway, and they must be memorised as a pair. The broken yellow line shows on the ground the zone of effect of the "parking prohibited" sign, and the solid yellow line the zone of effect of the "stopping prohibited" sign. The form of the marking reflects the severity of the prohibition: broken means less strict, solid means stricter.
This mnemonic simplifies a driver's daily work. If you have not seen the sign, or it was hidden behind a tree or a lorry, the colour on the kerb settles your position. A broken yellow line means you may stop briefly to pick up or set down passengers or to load, but you have no right to park. A solid yellow line means even a brief halt is not permitted.
The safety logic of this distinction is clear too. Where parking is prohibited, the problem is the long occupation of space and the reduction of the road's usable width; a short, controlled stop is still tolerable. But where stopping is prohibited, even those few seconds blind the view or block the flow — near a junction, on a bend, on a bridge or in a tunnel. The trap of the third option is that signs about parking on odd and even days have no accompanying yellow marking and are not indicated by markings on the kerb.
• The "stopping prohibited" sign is accompanied by a solid yellow line, not a broken one; the stricter prohibition has the continuous marking. • Signs about parking on particular days of the month are not accompanied by this marking; their restriction is temporal, not a zone marked out on the kerb.
