Ticket 3 · question 38 Updated:
  1. The threaded joints of the steering wheel are not tightened or secured in the specified manner.
  2. There are no fire extinguishers on the bus.
Correct answer In both cases.
Both the threaded joints of the steering not being tightened or secured and the absence of fire extinguishers on the bus.
This question places a mechanical defect in the steering system alongside an item of mandatory equipment; both are on the list of prohibiting defects.
The threaded joints of the steering system must be tightened and secured in the prescribed manner — to a specified torque and with a self-locking nut, split pin or locking wire. The reason is vibration: the steering constantly takes shocks from the road surface, and a bolt that is merely tightened but not secured works loose over time. The end result is a steering rod or ball joint separating while the vehicle is moving; that is, a complete and sudden loss of directional control with no prior warning. No other system in the vehicle can take the steering's place.
A fire extinguisher on a bus has an equally clear logic: fire in a vehicle carrying dozens of passengers with one or two exits becomes a disaster within minutes. The extinguisher is for those first few minutes — while the fire is still limited and containable and the fire brigade's arrival will take several times as long.
Worth memorising: for a bus, keep three items of mandatory equipment together — the first-aid kit, the fire extinguisher and the emergency stop sign. The absence of any one of them prohibits movement on its own.
• Correct but incomplete; untightened threaded joints in the steering really do prohibit operation, but the option drops the bus fire extinguisher item. • The absence of a fire extinguisher on a bus is independently prohibiting too; choosing it alone makes the answer incomplete.
