Ticket 3 · question 63 Updated:
  1. There are visible tears on the seat belt intended by the structure ✓ Correct answer
  2. Not equipped with fog lamps
  3. In both cases.
Correct answer There are visible tears on the seat belt intended by the structure
When there are visible tears on the seat belt provided for in the vehicle's structure.
A defective seat belt — visible tearing on the webbing, a broken buckle or a failed retractor mechanism — prohibits operation of the vehicle. Note that the criterion is being "provided for in the vehicle's structure": if the manufacturer designed a belt for that position, that belt must be sound.
The reason for this strictness is how the webbing behaves at the moment of impact. In a collision the belt must withstand a force several times body weight and spread it across the pelvis and ribcage. The webbing's woven fibres carry this force only while they are continuous; a small tear creates a stress concentration point, and the webbing parts exactly there and exactly at the moment you need it. A torn belt is worse than no belt, because it gives the occupant a false sense of safety and stops him taking other precautions.
The fog lamp option is a familiar trap in this chapter. Fog lamps are optional equipment; not having them creates no prohibition, and only if they are fitted must they work properly and be used in accordance with the rules. Keep the general rule: the absence of optional equipment is not an offence, but a fault in, or the absence of, equipment provided for in the structure is.
• Fog lamps are optional equipment and not having them brings no prohibition; only if fitted must they be sound and used correctly. • Since not having fog lamps is not an offence, "in both cases" is wrong and only the torn belt matters.
