What do these road signs show?
Ticket 4 · question 60 Updated:
  1. Pulling off to the side of the road is dangerous due to repair work. ✓ Correct answer
  2. Repair work is being carried out on the road.
Correct answer Pulling off to the side of the road is dangerous due to repair work.
Pulling off onto the roadside is dangerous because of repair work on it.
The red-bordered triangle with a worker symbol is a roadworks warning, but it is the plate beneath it that gives the answer: the image of a vehicle whose nearside wheels have dropped onto dug-up, uneven ground means a dangerous shoulder — pulling off onto the shoulder is unsafe because of work in progress on it. The picture confirms this: the carriageway is open and its asphalt sound, but a loader is working exactly on the right-hand shoulder and its surface is strewn with earth and gravel.
The safety reason matters more than the wording of the sign. A shoulder under repair may be dug out, soft, or at a sharp difference in level from the asphalt. If you drop a wheel onto such a shoulder at speed, the friction on the two sides of the vehicle suddenly becomes asymmetric, the vehicle is pulled towards the shoulder, and a hasty attempt to correct with the steering can end in a swerve into the opposing lane or a rollover. So here you should not leave the asphalt to make room for the vehicle behind, or for a brief stop, or to let someone past; just reduce speed and stay on the carriageway.
The general rule for this kind of question: when there is a plate beneath the sign, an answer that ignores the plate is wrong. A plate always makes the sign's meaning more precise and more limited.
• This sentence merely repeats the meaning of the triangle above and drops the plate; whereas the question asks about "these signs", and the hazard announced is specifically on the shoulder, not on the carriageway.
