What are the signs of principal arterial bleeding and how does first aid for principal arterial bleeding begin?
Ticket 10 · question 44 Updated:
  1. Dark blood flows slowly out of the wound. A compression bandage is placed on the wound on which there is a note on the time of holding it on the wound.
  2. Bright red blood flows from the wound, spouting strongly with intermittent flush or like a fountain. The injured artery should be squeezed with the fingers, then above the wound, as far as possible near the wound, a bleeding cord is placed, on which there is a note about the time for keeping it on. ✓ Correct answer
  3. Blood flows slowly from the wound. A bleeding cord is placed below the injury, with a note of time for keeping it on.
Correct answer Bright red blood flows from the wound, spouting strongly with intermittent flush or like a fountain. The injured artery should be squeezed with the fingers, then above the wound, as far as possible near the wound, a bleeding cord is placed, on which there is a note about the time for keeping it on.
