In this situation, which turn signal must the driver switch on when stopping?
Correct answer Left
- If you intend to stop immediately after the intersection, when must you switch on the right turn indicator so as not to mislead the other road users?
- Where to stop at a traffic light signal?
- What must the driver of a vehicle do when approaching an intersection with a "stop line" and a green traffic light?
- Is it required to make a signal with a indicator light when maneuvering at the parking lots or vehicle filling stations?
