What trajectory is allowed to bypass an obstacle in this situation?
Ticket 4 · question 69 Updated:
  1. Only "a".
  2. Only "b".
  3. "a" and "b" ✓ Correct answer
Correct answer "a" and "b"
Both trajectories "a" and "b"; the obstacle may be passed on the right or on the left.
On the obstacle in the middle of the road — that red divider beneath the bridge — a round blue sign is mounted bearing two arrows, one deviating to the left and one to the right. That is exactly what this sign means: pass on the right or the left of the obstacle. So trajectory "a", which goes round the right, and trajectory "b", which goes round the left, are both permitted and the choice is yours.
This sign has two sisters whose arrow is single-headed and which leave only one side open; tell them apart by the number of arrows, not by habit. That is exactly where the common exam trap lies: many, recalling the general rule of keeping right, immediately choose "right only", whereas the two-arrow sign expressly sets that rule aside at this point.
The reason such a sign exists is practical: when a bridge pier or a central island divides the carriageway into two passable openings, closing one of them would only create queues and needless stopping. Even so, permitted does not mean safe; before choosing a side, judge the width of the opening, the oncoming vehicles and any pedestrians. In this very picture two people with bicycles are standing on the left beneath the bridge, so if you choose trajectory "b" you must reduce speed and leave adequate lateral clearance.
• Trajectory "a" really is permitted, and that is what makes this option deceptive; its fault is exclusivity. With two arrows the sign has left the left side open too, and there is no reason to eliminate "b". • Trajectory "b" is permitted as well, but if the sign wanted passage on the left only, its arrow would be single-headed and pointing left; here both sides are marked.
