The use of motorcycles with side attachment is prohibited if:
Ticket 3 · question 26 Updated:
  1. There is transverse grip for the passenger on the saddle.
  2. The residual height of the tire tread is 0.6 mm.
  3. The med kit is missing.
  4. In all the listed cases. ✓ Correct answer
Correct answer In all the listed cases.
In all the listed cases — the absence of a transverse grip for the passenger, a tyre tread of 0.6 mm, and the absence of a first-aid kit.
All three items in this question separately appear on the list of defects prohibiting the operation of a motorcycle with a sidecar, so the comprehensive answer is correct.
The first option refers to the absence of a transverse grip on the saddle. A motorcycle passenger has no seat belt and no bodywork; that grip is his only point of support. Under hard braking or sudden acceleration, a passenger without a grip either presses against the rider and upsets his control, or slides backwards. The second item is numerical: the minimum permitted tread depth for a motorcycle is 0.8 mm, so 0.6 mm is below the legal limit and not permitted. A bald motorcycle tyre has almost no grip on wet asphalt, and because a motorcycle has only two contact patches, a slide leads directly to a fall. The third item is mandatory equipment: a motorcycle with a sidecar carries a passenger and must have a first-aid kit.
The exam trap is the figure 0.6; if you have memorised only 1.6 (which applies to passenger cars), you may think 0.6 is "enough" for a motorcycle. Keep this chapter's three key figures together: motorcycle 0.8 · passenger car 1.6 · bus 2 mm.
• This item is correct on its own — a motorcycle with a sidecar must not move without a transverse grip for the passenger — but it ignores the other two conditions. • A tread of 0.6 mm really is below the permitted 0.8 mm and creates a prohibition, but choosing it alone leaves the answer incomplete. • The absence of a first-aid kit is independently a ground for prohibition too; again correct but incomplete.
