The bus has stopped, giving way to pedestrians. Does the driver of the car violate the traffic rules in this situation?
Ticket 7 · question 57 Updated:
  1. Violates. ✓ Correct answer
  2. Does not violate.
Correct answer Violates.
Yes, the passenger car's driver is breaking the rules.
In the picture the bus has stopped before the pedestrian crossing — the markings on the carriageway with the crossing sign on the right — to give way to pedestrians, and the red car is passing beside it and approaching the crossing.
Two rules are broken at once. First: when a vehicle in the adjacent lane has stopped before a crossing, other drivers may continue only after making sure there is no pedestrian; in practice that means you must stop and look. Second: overtaking and passing on a pedestrian crossing is prohibited.
The safety reason speaks more clearly than the rule itself: the bus's tall body acts as a wall. The pedestrian crossing in front of the bus does not see the red car, and the red driver does not see him; they discover each other at a moment when the distance is a few metres and the car's speed has not changed. This pattern is one of the deadliest urban crashes.
Worth memorising: read every vehicle stopped before a crossing as a warning, not as an obstacle. Its message is: "someone is crossing whom you cannot see".
• The temptation is that the red driver sees no pedestrian himself and the way ahead looks clear; but that very "not seeing" is the reason for the prohibition, because his view is blocked by the bus's body.
