In what cases is towing prohibited?
Correct answer In icy conditions with a flexible hitch.
- What is the maximum speed allowed for passenger cars on roads outside populated areas?
- When towing on a rigid coupling, the distance between the vehicles must not exceed:
- Is it permitted to transport people in the back of a truck when towing on a rigid or flexible coupling?
- At what maximum speed is the traffic allowed when towing by mechanical vehicles?
- What is the maximum speed at which towing can be done under these conditions?
- When towing with a rigid or flexible coupling, which of the following is permitted to be transported in a towed vehicle?
- Towing in icy conditions is prohibited:
