The driver of the white passenger car in this situation
You must give way to the bus pulling out from the marked stop. The stop sign is visible on the right and the red bus is starting off from exactly that place; within a built-up area drivers must give way to public transport vehicles setting off from a designated stop, so you slow down and let it join the flow. The exception exists because a bus is long, heavy and slow to accelerate: made to wait for a gap like an ordinary car, it would be trapped at the stop in peak hours with part of its body exposed outside the bay. Note the two conditions — built-up area and a designated stop — and note that the bus driver must still signal and make sure the move is safe.
- Are you obligated to give way to a passenger car if you continue driving straight ahead?
- From this lane, in which direction may the driver of the passenger car continue?
- Should the driver of a passenger car change his/her lane after overtaking the right lane?
- Is the passenger driver allowed to start movement?
- Is the passenger car driver allowed to approach the passenger on the bridge while reversing?
- Is it allowed to approach the passenger with reverse?
