In which direction is traffic prohibited?
Correct answer Left and right
Left and right are prohibited; only straight ahead is open. Read the two elements together: the round sign with the wide red border is No Entry, and the plate beneath it with a double-headed horizontal arrow defines its scope — the prohibition applies to the roads on the left and on the right of this intersection. The rule this question teaches is that a plate under a sign is never a new sign; it narrows or specifies the scope of the sign above it, and the two must be read as one unit. Ignore the plate and you wrongly extend the prohibition to the whole intersection.
- On a two-way road with three lanes, you need to turn left. From which lane will you perform this maneuver?
