A traffic circle is arranged at the intersection. The roadway you are approaching an intersection has two lanes. Which lane do you have to take to turn when entering the intersection?
Ticket 1 · question 5 Updated:
  1. Right lane
  2. Left lane
  3. Right or left lane. ✓ Correct answer
Correct answer Right or left lane.
You may enter from either the right or the left lane. Entering a roundabout is an exception to the normal lane-positioning rule: you are not restricted to the rightmost lane as you would be for an ordinary right turn. The reason is structural — a two-lane approach must be able to feed a multi-lane ring, otherwise a queue forms at every entry. The exception disappears if directional arrows or lane-direction signs are posted at the entry, and a Give Way sign still obliges you to yield to traffic already circulating.
