At what distance from the location of the dangerous part of the road are these signs placed in the settlements?
Ticket 4 · question 5 Updated:
  1. 15-25m.
  2. 25-50m.
  3. 50-100m. ✓ Correct answer
  4. 100-150m.
  5. 150 - 300 m.
Correct answer 50-100m.
50 to 100 metres before the dangerous section of road.
All five signs in the picture belong to the warning family: a level crossing with barriers, a level crossing without barriers, a junction of equal roads, traffic lights and "other dangers". A single placement rule applies to all of them: within built-up areas, 50 to 100 metres before the hazard, and outside built-up areas, 150 to 300 metres.
The logic of these two figures is the distance needed to react. Outside town, at speeds approaching 90 km/h, the driver needs a greater distance in which to see, decide, slow down and if necessary stop. In town the speed is lower, but the density of junctions, yard exits and signs is high; a sign posted much further away loses its mental connection with the hazard and the driver forgets it before he arrives.
Keep the point to memorise as a pair: "50 to 100 inside, 150 to 300 outside". Note that these distances are for warning signs; prohibitory and priority signs are usually posted immediately before the point where they apply and are not covered by this rule.
• 15 to 25 metres is so short that at urban speed it is covered in about a second; effectively no opportunity to react remains. • 25 to 50 metres is also below what is needed for effective deceleration and falls within neither of the two standard ranges. • 100 to 150 metres is an undefined range and falls exactly between the two correct figures; for that reason it is the most deceptive option. • 150 to 300 metres is the correct answer, but for outside built-up areas; the question asks about inside a built-up area, and that very substitution is the main trap.
