Correct answer Bus driver
The bus driver must give way; the tractor goes first. Being slow does not deprive a vehicle of its priority: a tractor, road machinery or any other slow-moving vehicle is assessed at an intersection by exactly the same order as everyone else. Low speed imposes only one duty on its driver, and that applies outside intersections — if a queue forms behind, they must pull over where it is safe and let others overtake. Here the bus's path crosses the tractor's, so the bus stops; and because a tractor is slow and often wide, giving way means waiting until it has cleared the intersection completely.
- Are drivers of vehicles in populated areas required to give way to public vehicles starting from a designated and equipped haul ting point?
