Which of the following road markings indicates the part of the intersection where entry is prohibited if there is a traffic jam in the direction of the traffic, which will force the driver to stop?
Ticket 4 · question 84 Updated:
  2. 2
  3. 3 ✓ Correct answer
Correct answer Option 3 — 3
Marking number 3; the yellow lattice grid.
Marking number 3 is the yellow lattice grid painted on the surface of a junction, and its meaning is one thing only: do not enter this area until you are sure you can clear it completely. If a queue has formed ahead in your direction and your entry would leave you standing in the middle of the junction, entry is prohibited — even on a green light.
The safety and functional reason for this marking is junction gridlock. A vehicle stuck in the middle of a junction blocks the path of the perpendicular flow; that flow then gets stuck at the next junction, and within a few minutes a whole street network locks up. More important than the traffic, the route for ambulances and fire engines is blocked, and drivers stranded behind a stuck vehicle resort to nervous, high-risk manoeuvres. The yellow grid makes this area visually a "no-stopping zone" so that no excuse for blind entry remains.
Worth memorising: keep the yellow colour and the grid pattern together. A green light gives you permission to proceed, not permission to enter a full junction. The final decision is yours: if you have no space to exit, stay behind the line.
• Parallel yellow stripes are the marking of a pedestrian crossing; they identify where pedestrians cross and have nothing to do with entering a junction during congestion. • A chevron pattern indicates a guiding island; a place where traffic flows separate or merge, and entry by a vehicle is prohibited in general, not only during congestion.
