At what maximum speed can the driver of the towing bus move in this situation?
Correct answer 50 km/h.
- What is the maximum speed allowed for passenger cars on roads outside populated areas?
- When towing on a rigid coupling, the distance between the vehicles must not exceed:
- At what maximum speed is the traffic allowed when towing by mechanical vehicles?
- What is the maximum speed at which towing can be done under these conditions?
- What is the maximum speed at which vehicles may be towed on a flexible coupling?
- When towing a motor vehicle outside built-up areas, the speed should not exceed:
- What is the maximum speed allowed for passenger cars with trailers on highways?
- What is the maximum speed allowed when towing with a flexible hitch?
