The driver of a vehicle equipped with a blue flashing beacon has priority over other road users if:
Correct answer Turns on the flashing beacon and gives a special sound signal.
- If the values of traffic lights signals contradict the requirements of traffic priority signs, drivers should be guided by.
- Is the bus driver obliged to give way to an ambulance if it does not have a blue flashing beacon and a special sound signal on?
- Are you obliged to give a signal with the turn indicator in the indicated situation?
- When approaching a stationary vehicle with a red flashing light on, the drivers of public vehicles traveling in that direction should:
- In the absence or malfunction of a turn signal light, the warning signal by hand is discontinued:
- When approaching a parked vehicle with a red flashing beacon on, drivers of vehicles moving in that direction must:
