Who do you have to give way to if you intend to continue driving straight ahead?
To both vehicles. The inverted triangle Give Way sign on the right, together with the junction-layout plate, states that the major road crosses your path and you are on the minor road. The yellow bus passing ahead and the gold car coming from the right are both travelling on that major road, and a driver entering from a minor road must yield to every vehicle on the major road — it makes no difference whether they come from the left or the right, or what type they are. You may enter only when the way is clear from both sides. Give Way does not mean a compulsory stop, but where visibility is limited you will in practice have to stop to be sure.
