At this intersection the driver
Ticket 6 · question 60 Updated:
  1. Will pass the first ✓ Correct answer
  2. Ought to give way to the tram
Correct answer Will pass the first
You pass first.
The traffic light on your right is green and the additional section beside it is dark; that is, you have permission to move straight ahead and, as the rails show, your path goes straight through the junction. The blue-and-white tram is on your left travelling in the same direction as you, with its side indicator lit; that is, it wants to leave its path and change direction.
The main point of this question is a correction of belief: the tram's precedence is not absolute. A tram takes precedence over non-rail vehicles when the light permits both the tram and you to move at the same time and your paths cross in different directions of the junction. But a tram travelling in the same direction as you and wanting to change its path is performing a manoeuvre; and a manoeuvre, by whatever vehicle, creates no priority. Whoever is travelling straight without changing direction takes precedence.
The safety reason for this order is clear: a car coming at normal speed on a straight path does not expect a vehicle to turn in front of it from the side; its stopping distance is not designed for such a surprise. The burden of decision must rest on the one who is changing the situation.
Even so, in practice never get close to a tram and never stay in its blind spot. A tram cannot deviate and its braking distance is very long; having priority does not prevent a collision.
• This option rides on the memorised sentence "a tram always takes precedence". That precedence is conditional and does not extend to a same-direction tram that is changing its path; here it is you who are travelling without changing direction.
