Which vehicle must you give way to if you intend to make a left turn at an intersection?
Ticket 1 · question 57 Updated:
  1. The bus
  2. The bus and passenger car.
  3. The passenger car only.
  4. None ✓ Correct answer
Correct answer None
To none of them. The yellow diamond on the right is the Major Road sign and the white plate beneath it shows how the major road runs: the thick line comes from your side and turns left at the intersection, so by turning left you stay on the major road rather than leaving it. The dark car approaching from the opposite side is on the straight continuation, which that plate marks as minor, so its driver must give way to you. The yellow bus is to your left, and even on the major branch, a vehicle entering from your left yields under the right-hand rule. Never read the yellow diamond without its plate — that small plate decides whether the major road runs straight or turns, and it reverses the whole answer.
