What does the letter "A" on the lane of the roadway mean?
A special lane designated for the movement of public-transport vehicles.
The letter "A" painted in white on the carriageway in the picture is a dedicated marking with a fixed meaning: this traffic lane is reserved for public-transport vehicles. The corresponding blue sign is usually fitted above that lane or beside the road as well, to mark the start of the zone.
By a public-transport vehicle is meant one that carries passengers on a fixed route with designated stops: a route bus, a trolleybus, a fixed-route minibus. A private car, a taxi and a tour bus do not fall within this definition.
The safety reason for separating this flow is the difference in movement pattern: a public-transport vehicle stops at the right-hand verge every few hundred metres and pulls away again. If these stops are mixed into the through traffic, rear-end impacts increase and passengers alight in the gap between the bus and moving cars — the most dangerous possible situation for a pedestrian.
Worth memorising: not every letter or number you see on the asphalt is a road number. In the exam, "A" always refers to the dedicated public-transport lane and has nothing to do with licence categories.
• A road number appears on roadside signs and in the form of a route code, not as a single letter on the surface of the carriageway. • Licence category "A" relates to motorcycles, and no dedicated traffic lane with a marking on the asphalt is defined for licence categories.
- How many traffic lanes does a road have where traffic lanes of opposite directions are separated by double solid lines?
- Which vehicles are allowed to drive in the right lane of the roadway?
- Is the driver of a tour bus allowed to enter the "A" lane if this marking is present?
- In populated areas, on roads with one lane of traffic in each direction, in the absence of streetcar tracks in the middle, stop and park on the left side of the road:
- Is the tourist bus driver allowed to drive in the "A" lane?
- In which of the following cases can a bus driver take the middle lane on a three-lane two-way road that is used for traffic in both directions?
- For which vehicles is the lane marked with the letter "A"?
