Which vehicle must you give way to if you intend to make a left turn at an intersection?
Ticket 1 · question 58 Updated:
  1. Truck
  2. All vehicles. ✓ Correct answer
  3. None.
Correct answer All vehicles.
To all vehicles. There is neither a priority sign nor a traffic light at this intersection, so it is an intersection of equal roads, governed by the right-hand rule together with the rules for turning left. Three duties apply at once: the tram approaching on rails from the left, the army truck coming from the crossing road on the right, and the car approaching head-on. At an intersection of equal roads a tram has priority over non-rail vehicles regardless of its direction, because it cannot steer aside and its braking distance on rails is several times longer. Note that the right-hand rule applies only among non-rail vehicles — the tram sits outside it and goes first even when it comes from the left.
