Which vehicle must you give way to if you intend to continue driving straight ahead?
Correct answer Only a bus and a passenger car.
Only the bus and the passenger car. The inverted triangle Give Way sign on your right, with a junction-layout plate beneath it, shows that the major road runs across your path from left to right — so you are on the minor road and must yield to everything travelling on the major road: the yellow bus crossing ahead and the gold car coming from the right. The motorcycle on your left is not on the major road; it waits behind the same minor road as you, and between two vehicles on the same level of road, priority goes to the one on the right — which here is you. Always place each vehicle on the major or minor road first, then count.
