Do we have to give way to the driver of the oncoming car in this situation?
Ticket 1 · question 64 Updated:
  1. Yes ✓ Correct answer
  2. No
Correct answer Yes
Yes, you must give way to the oncoming car. There is no gradient sign on this road — it is level with two lanes — and the tanker with hazard lights and a warning triangle behind it is standing in your lane, so the obstruction is on your side, not the other driver's. The rule is clear: where an obstruction makes passing difficult, the driver whose lane is blocked gives way, because it is that driver who has to enter the opposite lane. Hazard lights and a warning triangle on a stopped vehicle are warnings only and create no right of passage for you. If the same picture had an ascent sign facing you the answer would reverse — always look for a gradient sign first.
