Which vehicle driver correctly performs a U-turn?
Correct answer The driver of the red car
The driver of the red car. Before making a U-turn you must position the vehicle in the leftmost lane of your own direction, and the red car starts its manoeuvre from exactly that lane. The blue truck is one lane further right, so its turning arc cuts across the adjacent lane and passes in front of the red car — and its greater length makes the arc wider and the occupation longer still. The centre line is broken on their side, so crossing it is not the issue; what makes a U-turn correct or incorrect here is the lane it starts from, and signalling alone is not enough.
