Maneuvering means
Manoeuvring comprises starting movement connected with entering the adjacent lane, changing lanes, changing the direction of travel, stopping accompanied by a lane change, and making a U-turn.
A manoeuvre is the set of movements that alter the vehicle's lateral position and may cut across others' paths: starting movement connected with entering the adjacent lane, changing lanes, changing the direction of travel, a stop performed with a lane change, and a U-turn. The qualifiers in brackets are the core of the definition, and dropping them makes the answer wrong.
The technical logic is that the duty attached to a manoeuvre — signalling with the indicator and giving way — is meaningful only when your movement blocks someone. If a vehicle starts moving within its own lane, or stops within that same lane, no other lane is occupied and nobody is forced to brake or change course. But the moment the adjacent lane comes into play, you become an obstruction to someone already travelling in it; he is established in the flow and you are entering it, so priority is his. The legal definition draws exactly this line.
• A definition without the qualifiers "entering the adjacent lane" and "stopping with a lane change" is too broad and counts every stop or start as a manoeuvre, even when no other lane is occupied.
- According to the Law of the Republic of Armenia "On Ensuring Road Traffic Safety", persons holding "B", "C" and "D" category driving licenses are allowed to drive them with attachments, if the maximum permissible mass of the attachment does not exceed:
